KA24DE Engine Diagram
Tha Darkness
Car: 1991 240sx SE Coupe
If I'm stating that correctly. Can anyone post a link, where I can view every part of the engine? I was changing my thermostat last nite on a friends car, threading in the bolt and cracked of a piece of metal (within tha thermstat housing, need to know what part this is). Of 3 bolts, 2 located on top and one on tha bottom, its tha one on tha bottom. The part it screwed onto was connected to a rubber hose and a clamp in the back, also connected to tha block on its side. Piece is rusted, which he was over heating for a week. Sucks
Any help please?
Thanks
Modified by Tha Darkness at 3:01 PM 1/13/2006
onosqv
Car: '92 240sx Vert
just take out one of the good bolts, go to ace hardware or some other hardware store, and match up!
But if you really want a part #, check out http://www.carfiche.com - takes a little getting used to, but will give you the part # - once you have that, either go dealer or check out midway (below - probably not cheaper w/ shipping but if you buy other stuff may work out good).
Tha Darkness
Tha bolt did not break. Its the thermostat housing: tha bottom piece where the bolt goes into broke off, needing a whole new piece. But once again, I dont know what that part is. Thus needing pictures to identify it?............
Modified by Tha Darkness at 3:43 PM 1/13/2006
onosqv
Car: '92 240sx Vert
Tha Darkness wrote:Tha bolt did not break. Its the thermostat housing: tha bottom piece where the bolt goes into broke off, needing a whole new piece. But once again, I dont know what that part is. Thus needing pictures to identify it?............
Ok, I wasn't reading too clearly then, but you should have read the rest of what I said:
brokeAs240sx wrote:http://www.carfiche.com - takes a little getting used to, but will give you the part # - once you have that, either go dealer or check out midway (below - probably not cheaper w/ shipping but if you buy other stuff may work out good).
onosqv
Car: '92 240sx Vert
Also, taking a picture of what you are talking about may help a little.
What it "might" be is the thermostat itself?
Because it goes hose->thermostat housing->thermostat->block.
So if you broke something metal, it's either the housing or the thermo.
Tha Darkness
brokeAs240sx wrote:Also, taking a picture of what you are talking about may help a little.
thanks dood, its definitely not the thermostat itself, the housing (thick metal). I'm checking it out now.
onosqv
Car: '92 240sx Vert
If it's the thermostat housing, you could have just asked for a part # for that
not part #, but direct link:http://www.trademotion.com/partlocator/index.cfm?actio...
Tha Darkness
This part is connected to tha block, we need to weld it......possibly jb weld.
Tha Darkness
eb weld did the trick
Modified by Tha Darkness at 6:26 PM 1/17/2006
