kibblez »
https://forums.nicoclub.com/kibblez-u103506.html
Wed Nov 26, 2008 11:10 am
91 240sx S13 [ka24de] 3 in. exhaust
Noob needs help,I have searched for similar threads but didnt come up with too many results so i appologize for reposting if this has been said before. If you stick through the whole thing i appreciate your time and any advice is greatly appreciated as i have just failed my 6th emissions testing.
Arizona emissions, testing HC, CO, and NOX levels.
first test, passed HC and NOX just barely and failed CO pretty bad.
Checked injectors, O rings were getting pretty torn up so replaced rings, replaced plugs after being dumped with fuel, check timing, no evidence of anything else being suspect.
second test, failed all three with flying colors. HC, CO, NOX all sky high.
Checked injectors, still having torn up O rings, replaced rings again with O Rings from Home Depot, changed plugs again, timing, checked dizzy, wires, fuses, everything seems good.
tests three - four, did checks on everything, i cant remember everything i did but i gained confidence again and retested. fail.
Ran Seafoam through, smoked out the neighborhood, ran HEET, fuel injector cleaner, heet and seafoam through the gas tank, changed oil, plugs good, wires good, re-taped wiring, no evidence of vacuum leaks, nothing disconnected, EGR service test was good, did timing, MAF good, replaced air filter, faked the AIV, mixed 91% rubbing alcohol with 91 octane gas 1/4 tank and pulled an injector, time for retest #5.
Passed HC and NOX and still failed CO barely.
checked plugs, evidence of running lean. Ran self diagnostic, giving code 34, repaired knock sensor, gave me code 55, all is good in 240 land. Timing seemed to have adjusted itself to normal. last minute inspection on everything, yayyy, retest.
sixth test, awww failed all three. Epic Failure.
Anyone have any ideas? Any advice is greatly appreciated. Thanks again.
