KA24DE EGR system
d1grandprix
Car: s13
Has anyone ever had problems with your EGR system? My check engine light came on. I checked the code and came out 32, which was the EGR system I believe. My KA sounds like it has a leak around my exhaust manifold. Sounds worst when actually driving the car. Sounds sort of like those Honda that have freeflow without exhaust, but a lower similar noise. Noise gets worst around 2500 rpm up and in between gears. Anyone think this noise is caused by a EGR system leak?? Could a EGR system leak be this fck'in loud? I'm just sick of the check engine light and especially the noise.
240sx man
I just went through this,take the BPT valve off it is right next to the EGR valve...it is held on by 2 10mm bolts, it has 3 lines on it 2 on top and one on the bottom that is a 90 degree bent hose, on mine that hose was split, not giving the proper signal to the BPT to open the EGR valve,also the exhaust leak will not allow sufficient signal to operate the BPT, fix the exhaust leak and check the small 90 degree bend hose under the BPT....................
