ka24de egr head removal question
fuco8210
I unfortunately have to rip the head again and replace the hg that lasted 3000miles. Last time i remember getting the egr plate free(and reinstalling) from the intake manifold was a huge pita. and the fitting on the exhaust manifold wasnt going to come off.. This is a main reason why i have been putting this job off, but its time to try again and get the 240 back on the road. I am looking for hints on the best way to get the egr off and back on when i rip/reinstall the head.. thanks
fuco8210
nobody?
clss240
Car: 1990 240sx hatch
i just used a large adjustable wrench and heavy rubber malet to unscrew the fitting at the header once the egr pipe is off the header you should be able to unbolt the manifold as usual and the remove the head right?
TDS
Car: 2008 G35
Do you absolutely need to have the EGR installed? Why not go without it unless your state has strict emissions.
fuco8210
TDS wrote:Do you absolutely need to have the EGR installed? Why not go without it unless your state has strict emissions.
I have a block off plate but i still have not gotten the car registered. salvage title= bs lol probably would have it done already but it keeps breaking on me
4cefed
Car: 92 240SX Coupe
03 SRT-4
Various Dodge POSs
Is there a thre4ad somewhere about removing the EGR? I was going to do it when i swapped engines, but I didn't want to mess with the variable intake stuff that is in the same area.
psi240
Car: 1997 240sx
zerothread/157751
variable intake stuff ? are u talking about the butterflies? if ur going to be taking off the IM anyways then take them out .. its really easy.
4cefed
Car: 92 240SX Coupe
03 SRT-4
Various Dodge POSs
psi240 wrote:zerothread/157751
Thanks for the link. I'm not going to do a turbo conversion so as I understand, the butterflies would be best left in. At lower rpms the will induce more torque. For a turbo swap it makes prefect sense since the boost at lower rpms will add torque, and not having the intake restricted with butterflies will help the top end.
Has anyone done a dyno comparison on an NA engine?
motoman399
Car: 98' wrecked (RHD coming soon) 240
fuco8210 wrote:I unfortunately have to rip the head again and replace the hg that lasted 3000miles. Last time i remember getting the egr plate free(and reinstalling) from the intake manifold was a huge pita. and the fitting on the exhaust manifold wasnt going to come off.. This is a main reason why i have been putting this job off, but its time to try again and get the 240 back on the road. I am looking for hints on the best way to get the egr off and back on when i rip/reinstall the head.. thanks
the way that i do it is i spray it with penetrating oil maybe use some heat like a propane torch. loosen the header/manifold and then use your wrench or vise grips or what ever you use, and when you install it put anti-seize on the threads. should work pretty good
