ka24de ecu swap years
RB260sx
Car: s14.5 260sx
i been looking through the forums no such luck on ka24de ecu for the manual dohc 91-98. just wondering if they are interchangable with different year of ka24de motor? please help
Modified by RB260sx at 4:06 PM 3/9/2007
dkdeleon68
Car: 1991 240
you can use a auto ka24de ecu on a manual to cut the speed limiter.
RB260sx
Car: s14.5 260sx
what about the motor can i use like a 92 ka24de ecu on a 98 motor?
dkdeleon68
Car: 1991 240
Yes, but you will have to swap the lower 98 ka24de intake plenum with the 91 ka24de intake plenum along with the distributor and throttle body so the wiring harness will connect up right. Reason is, is that the 98 is OBD 2 and the 92 is obd 1. Changing the lower intake plenum will make the 98 OBD 1
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
RB260sx wrote:i been looking through the forums no such luck on ka24de ecu for the manual dohc 91-98. just wondering if they are interchangable with different year of ka24de motor?
The 91-94 ECUs should be the same which use OBD-I and the 95-98 ECUs should be the same which use OBD-II; the two ECU groups are not interchangable.
RB260sx
Car: s14.5 260sx
Thanks, what is OBD? and for the speed limiter, i can use auto ecu to cut it off? thats cool but only it has to match either obd-I or obd-II motor right?
Modified by RB260sx at 10:59 AM 3/10/2007
480sx
Car: 1996 Pearl White 240sx
OBD = On board diagnostics
The idea of OBD was to simplify a mechanics job by making everything standard throughout the whole car industry. In fact it did kinda the opposite, and if you talk to any tech about OBD2 you will get an ear full.
OBD2 is the second version, and the update was primarily to add emission control stuff. Specifically a system that gets rid of fuel vapors, it is called an evaporative emissions system.
Hope that answers your question.
