MoldyOldy240 »
https://forums.nicoclub.com/moldyoldy240-u41784.html
Mon Nov 26, 2007 3:47 pm
Alright; so originally I was pulling a 32 34 and i believe a 45 (whatever the EGR code is).
Put a new o2 sensor in and wiped the ecu; drove it down to the gas station and filled her up with injector cleaner and 91 octane (the highest you can get in California).
Nothing sparked up till I went past 45, then the check engine light would come on during full throttle, then go away. Eventually the check engine light would just stay on.
Wiped, rinsed and repeated, same results.
I understand the the codes are reading knock sensor and injector leak; but the only bogging or hesitation has been twice with 3rd gear at 5'500 there was a slight hesitation.
Could the knock sensor be cause the injector leak code?Any one have any ideas or similar experiences ?
I did a few searches and found some new ideas; I was just wondering if you all had any others.
