hpmachine »
https://forums.nicoclub.com/hpmachine-u34606.html
Mon Oct 19, 2009 8:59 am
I've got a ka-t with a JWT tuned ecu. The car also had a 5spd swap done. Using an s13 5spd. When I bought the car, the CEL was not on. Now it is. I pulled the codes and got p0325 which is knock sensor. The car runs perfectly. Pulls hard, no weird idle, revs perfect, my mpg is good as usual. The other codes are all for the AT. Why would these come up now? I've read that the knock sensor will not throw a CEL by itself. And if it was bad, it will pull timing which would be noticeable. What gives?
