Ka24de Dizzy problem really interesting
s14danny
Hi have an 1995 240sx with a s13 ka24de. I put an s14 intake and s14 dizzy. When i take the dizzy off and rotate it by hand i get a spark. But when it is installed I get no spark what so ever. HELP!?
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
100% positive you don't spin it when you install it? All of your engine grounds hooked up? Can you maybe make a video clip for me?
DamonDread
Car: 1987 Toyota Supra Turbo
No issues with the s13 harness pluggin into the s14 dist?
s14danny
Im using an s14 harness to the s14 dizzy. no s13 harness was used. the motor turns over really strong ill get video later today when i get off work. THANKS for the input guys. i have my intake grounded to the battery trey and the back of the head to a spot near fire wall.
s14danny
speedeast
are you re-timing the ignition every time you put it back in? Is the oil pump all the way in?
s14danny
yes i put it back at tdc every time and make sure its not 180 off. and yes the oil pump is in. this is to weird.
s14danny
anyone ever have this problem?!
nifares240
Car: 1993 240sx Black-Project Car, 1993 240sx Red-SOLD, 1994 Sentra, 2004 Nissan Sentra SE-R SPEC V-Daily, 1999 Toyota Camry
the dizzy has a tendency to shift when slide it in. keep redoing it.
dccse3k
regardless of the timing it should still spark maybe not at the right time but it should still spark. Seems to me for some reason your distributor isn't turning for some reason when you are starting it.
Try starting it w/ distributor out and look at the oil pump spindle to make sure its spinning. If it is there may be some electrical problem where it doesn't get power when it is starting?
motoman399
Car: 98' wrecked (RHD coming soon) 240
^^ that is right it should still spark even if its in the wrong spot. also it has absolutely nothing to do with the oil pump. on the ka24de the oil pump is in the timing cover unlike the shaft driven by the oil pump on the ka24e. so that is ruled out.
this is a really really strange problem. did you mess with any wiring or anything like that? check the gear on the idler sprocket on your timing set, maybe its messed up or missing somehow. and also try it again while grounding the distributor, maybe when it has ground it cuts out... somehow lol.
s14danny
motoman399 wrote:^^ that is right it should still spark even if its in the wrong spot. also it has absolutely nothing to do with the oil pump. on the ka24de the oil pump is in the timing cover unlike the shaft driven by the oil pump on the ka24e. so that is ruled out.
the wiring i got from a complete car that was running and driving fine. I replaced the whole body harness. battery harness dash harness engine harness and rear all from the same car. The motor was an s13 motor i replaced the intake, dizzy, and maf. i have done this many times before but for some reason the car has out smarted me this time. I'm going to try and ground the dizzy to another location and maybe switch out my ignition relays see if that goes anywhere...
s14danny
im starting to think my ecu might be bad?!
speedeast
it's not in the wiring, it sparks when you manually turn it... seems like the most likely issue is that something inside the motor isn't turning it... did you rebuild that motor, was the screw sprocket thing put on there correctly... im assuming it would only slide all the way in if it was.
sup_mario
Man check it if you installed it properly.
s14danny
Yeah i rebuilt that motor has new timing chain sprocket and so on. I'll take the timing cover off and see if it is. The dizzy goes all the way in and i feel the gears if its not aligned. This ordeal is so wack.
speedeast
Yeah, pretty wack, but probably a simple issue once we figure it out - usually is.
