ka24de cylinder 3 does not reach top completely
NISSAN240SX12
Car: 1993 NISSAN 240SX SE COUPE
1991 Toyota Supra
this maybe correct but im not sure. i have googled this and can not find any anwsers to this. all my cylinders will completely reach the top of the block but the third one. is this normal?
AZ89two4Tsx
Have you been trying to figure out this problem for the last four years?
NISSAN240SX12
1991 Toyota Supra
no. i have just ran into this. im installing new piston rings and i notice this when putting it all back together. my camera is not set properly for the todays date. i never use it because of the horrible picture quality.
Hijacker
Car: '92 240sx Convertible
'94 F-150
Rod's probably bent.
Nali
Car: Datsun Nissan 280ZX
AZ89two4Tsx wrote:Have you been trying to figure out this problem for the last four years?
Haha, LOL.______________________________________________________________OP ur cameras date is wrong.
keith0486
Hijacker wrote:Rod's probably bent.
24j0hn
Car: 91' 240sx with some babying to be given
it wasnt like that before?
*Rod could be bent*Forgot to install big end rod bearings*Rod is really out of round
killernoodle
Car: My daily: 2005 Cadillac CTS-V - pretty much stock
Brother's S13 project car: SR20det, wilwoods, suspension, q45 diff/axles, 315s out back
If there is no knocking then the rod is guaranteed to be bent... unless you somehow got a single piston for a stroker motor with the wrist pin slightly higher up on the piston.
This is HIGHLY unlikely... your rod is 99% probably bent.
NISSAN240SX12
1991 Toyota Supra
ok thanks everyone for the input. I called around and didn't find any 240's around the area so i called Nissan to verify that the Altima had the same exact internals. I headed down to the junk yard and pulled out the freakin rod out and it was a PITA! but anyways all is good and now back on track.
