asoomal »
https://forums.nicoclub.com/asoomal-u90618.html
Fri Mar 17, 2017 7:50 pm
A faulty sensor wouldn't cause such low compression readings.
Since all 4 cylinders are low, it is very likely that it is out of time. This could you also verify that the crank marks also line up?\
Missing ground wires do typically cause strange behaviours, but they are ECU related. In your case, it appears that it is a mechanical issue.
