KA24DE Crank Sensor?
Nismofreek823
Car: 1991 240sx Hatch
I have a 92' 240sx with a 93' KA. Has about 90k on the engine. I just replaced the upper timing chain and tension and removed the guides. The engine had rotated slightly when I was trying to break the cam gear loose and i didnt have it at TDC. So now it doesnt run. The engine is at TDC and I was just wondering if anyone knows where to set the cranksensor when the #1 is at TDC. I have 3 circle marks on the gear shaft, 2 big and 1 small. Thanks.
Tim
Nismofreek823
bump......please help
180fan
Car: 89 fastback
loosen your cams and get them to TDC along with your crank. Then line up the silver links to the punch marks on the sprockets.
Nismofreek823
I got that much, i'm talking about the distrubtor/crank senor. On the distributor shaft there are 3 dots.....2 big ones...and 1 small. Which of those is for #1 TDC?
s13sr20chris
