240ChukiSX »
https://forums.nicoclub.com/240chukisx-u140906.html
Mon Feb 15, 2010 10:33 am
Okay, so here is the issue. I have a 92' Hatchback and I've recently put in a new EXEDY OEM clutch, new slave cylinder, and new clutch master cylinder. Everytime I turn the car on it makes this loud noise like a scrape. Supposedly it has sumthin to do with my flywheel and my slave cylinder. It's agonizing. (Keep note that it only makes noises when I press down on the clutch pedal.) Also, my clutch fluid had to be refilled every drive especially long ones becuz it would constantly become low. SO, i went back to the mechanic that fixed my car and he said that it's an internal leak and that he bypassed this golden lookin squared metal cube where the clutch lines flow thru. So he tighten and bled my clutch again. After, it doesn't run low anymore. But he said that my clutch might've become sticky after the air got inside cuz of the leak. It still makes noises, not so much, but if I go from 3rd to 2nd to slow up, it makes that scraping noise again when I ride the clutch to shift. Can SOMEBODY help me? I've tried everything, and time and time again, it always happen. Thanx!
