KA24DE Cams
janda240sx
Car: 1995 240sx se
Would a 264/264 cam setup be to much for a N/A KA? Or would i be better off going with the OEM s13 248/248 setup?
speeds8r
Car: 1989 240 hatch / 1991 240 coupe w/96 motor 70k
That depends on what you want.....the 264's will give you a lopey idle and you'll lose some bottom end grunt but you'll gain more rpm and have more power up top. Also you may want to upgrade your retainers etc. for the larger cams. I think they recommend that for some 274's I've seen.
89coupe240
Car: 1989 240sx
i put some bc 264 cams in my ka and it was probably the best upgrade so for... barely any lope and awesome top end power
airman86
add another vote for the 264s. they don't "require" any modification to the head and they do supply a moderate boost in power.
