KA24DE Cams Specifications
TrukillaS14
Car: 95 Nissan 240sx w/97 Ka24de w/VLSD
so which cam is best to get from a 91-93 240sx or a 94, and is there any tuning I need to do.
mattaltima99
Car: 1999 Nissan Altima KA24DE, Spectra Cold Air intake, OBX 4-1 Headers, OBX 10.36 Spark Wires, Flowmaster super 44
Which Would Be better for an auto altima? 248/232, 248/248, 240/232? Im wanting to get as much horespower out of the ka24de before having totrbo it. Wold i be better off going to a stage 2 Jim wolf 275/275 with a .3 duration for more hp and tq gain? Thanks Matt
katillidie
Car: 1990 infinity m30
93 s13 coupe vq35hr swapped
96 s14
2003 m45
2000 frontier
Can u fill me in with more details on this?
"MAJOR NOTE: if an earlier ’91-’97 cam is used in any ’98 up engine, then the rear oil plug in the cam will have to be punched in deeper past the oil feed hole that feeds the rear most #6 cam bearing in order to avoid spraying oil around in the valve cover area!!!"
captn cookie
Car: 1996 Nissan 2.4 hardbody 4x4 king cab
Hello all,
I know this may seem like a dumb question, but what is the cam gear bolt size on the 2.4 hardbody p/u SOHC? I have used a 21mm and it wasn't it. that is as big as my set is. I don't want to buy tools that I don't need. Thanks in advance
Kitsune14
Car: 1998 auto s14a green - 217k - stock
1998 5pd s14a green - 300k - stock 140whp 140tq
1993 auto s13 hatch grayish - 167k - 94' Altima 248 cam swap - 3.93 j30 diff swap
Hey tloof! I know I'm reviving the dead here, but since no one has ever stated that they have installed the 93'-95' Altima exhaust cam as an intake I am here to say I did. your math was right, when I check valve timing it was visually the same as my s13 stock intake cam, while a s13 248 exhaust cam is aprox 5 degrees retarded visually.
I am going to be doing a write up at some point about the install, after I try some of the cam combos that djpants has tested and some that he hasn't.
ps.
would like your 2 cents on suggested combos like 93'-95' Altima 248/216 from 98'-99' Altima. after installing an oil hole on the 6th cam journal of course.
killrain
Car: 2004 XTERRA 2.4L
Lets see if some life can be brought to life here. I'm putting in 1997 Altima cams in my Xterra Ka24de. Would the valve clearance be the same specs as it shows in the manual? My apologies if it is a dumb question.
Timothy S
Car: 1998 Nissan Altima GXE, Auto RE4FO4A, KA24DE Engine
The valve clearance on the 1997 Altima was 0.012-0.015 in for the intake and 0.013-0.016 on the exhaust cam. The 1999 Frontier uses the exact same specifications, though it's exhaust cam has shorter lobes than the Altima tied not to valve clearance but exhaust valve duration. You probably will not need to adjust much if your truck was within spec before the cam swap.
taointn
Car: Xterra 2004 2.4L KA24DE 2wd
Hi all, I'm new to Nicoclub. Came here looking for some information and found this very excellent but originally old thread. I'm having a d!ck of a time finding an intake camshaft for a KA24DE (casting #F45) that's in a 2004 Xterra (2.4L of course). Haven't had any luck trying to order one from Nissan (out of stock - dealer says can't get) and southeast salvage yards can't locate. Any ideas? Can anybody recommend any shops that might sell one?
Regards,
Timothy S
If the earlier post is correct, the frontier and Xterra 00-04 should have the same intake cam as the 00-01 Altima. That's another option to look for at the junkyard. I'd start there if I wanted a stock camshaft. Pick-n-pull has always been my first choice. Always plenty of Altima there.
