I gotta get this thing timed right, as it is my daily driver.
Is this right? I dont think it is. I think my intake is right but my exhaust is wrong.
Are you referring to my pic of my cam setup?liquid_cool wrote:your wrong..the cams should be facing slightly upwards..looks like your a tooth off on both cams...start from scratch and set to TDC again...the intake cam should rest where it needs to be..the only one you need to move would be the exauhst cam down about 1/2 a tooth and your set...post a pic of your finnished work and ill check back to say ya or ney
StryfeS13 wrote:So it's not my distributor. I went to my friends apartment and set his motor to TDC and looked at how his rotor was. It was completely horizontal. The problem is we can not get mine to line up like that. It always is either slightly pointed up or slightly pointed down. The rotor will not go straight. We even tried his distributor in my car and it wont work.
If it makes any difference, you cant just "push" my distributor in, you have to tap it with a mallet.
