seang »
https://forums.nicoclub.com/seang-u122444.html
Sun Aug 30, 2009 9:49 am
This is for issue you described with braking hard from 70 while out of gear. The power brake booster relies on the intake for its vacuum supply, and when you slam the brakes while the engine is just idling away, of course its gonna mess with the idle and sputter a little bit. You said it stalls though, so IDK, just leave it in gear when you decelerate I guess.
