ka24de cam/idleing/timing problem, need input
thrasherx89
Car: 90 hatch (91 dohc, tein, z32, ss, injen, energy, b &m)
hey all
ok if i could get some help about this problem it would be great
when i got my 240 it had a cam swap, so i located some stock cams and put them in
i timed it, and it started right up and runs hard
the problem is that it will idle fine until you rev. it
once you rev it, it rev's good but then when it starts to rev. down it goes past the idle point and cuts out
could it be that the timing is off one chain link on either cam?
there is a small possibility that i bent cylinder 2 and 3 valves while trying to swap the cams because it was a learning curve for me
so is there a chance that if the valves are bent and that would cause it to be cutting out?
please let me know if any of you have gone threw that or know the answer to this problem
thank you!
