ka24de butterfly question
slipknot555_666_69
Car: 97 nissan 240sx
ok with the arm coming off the butterflies when its pointing up its closed and down is open correct?
slipknot555_666_69
anyone?
vancouverbc
Car: 1991 240sx
thought i had better pic
Modified by vancouverbc at 8:48 PM 12/18/2009
r3v_v3ng3
Car: 91 fastback ka-t
slipknot555_666_69 wrote:ok with the arm coming off the butterflies when its pointing up its closed and down is open correct?
on the pic the butterflys open. should be closed with full vacuum and opens as vacuum goes down i think
24j0hn
Car: 91' 240sx with some babying to be given
vacuum and pressure are inverse... so when vacuum is up pressure is down, and when vacuum is dowm pressure is up... like with fuel pressure, vacuum is up and pressure is down at idle... so when you start to accelerate vacuum is going down and pressure is increasing...
Didderson
Car: 1990 Nissan 240SX FB
'88 Nissan Hardbody pickup
'74 Datsun Z
uuuh. take them off, jb weld the holes. Problem solved.
24j0hn
Didderson wrote:uuuh. take them off, jb weld the holes. Problem solved.
im in the process of doing that for my ka-t...
gingerbredman
Car: 93 SE hatch, ~260k miles on the clock, 15" Enkei 92s, still stock. 2009 Sonata bouncing on Eibachs.
Just play with it. If it's the wrong way you will definitely notice something wrong in your powerband. I ziptied that actuator arm the wrong way (up/down??) and I thought the motor went kapoot..! ..had power up to 2k rpm lol, engine would scream and go nowhere..
