ka24de burning oil
240sxKAT89
Car: 1989 nissan 240sx se w/ka24de swap
hey guys, i have a problem with my ka burning oil. if i run it and then check inside the combustion chamber and there is a pool of oil. it is also using alot of gas so it could be mix of the two. but i just need to know how you think it could be getting in there.I just had the head off to replace head gasket bc it was burning coolant. now no coolant all oil. Please help
silpena
Car: Nis1993 san 240sx super hicas(wrecked)
soon to come to s-chasis
did u replace and re seal ur valve cover gasket? oil can get in from there and is common.
240sxKAT89
yeah, it turns out that coolant got in the oil and it was just too full(about 2 quarts or so). so then it was sucking it up through a breathing point into the intake then of course into the combustion chamber. i changed the oil and now its 100 times better. it still burns some oil but im sure the rings could be changed. Thanks for your help tho.
