ka24de bog problems??
fenderguitarist
Car: s13 coupe red top
ive been having a bog issue with my ka24de when i start it in the morning and drive it ill get a slight bog around the 1000-2000 rpm range then after it gets to operating temperature it really calms down but is still slightly there i checked the ecu and its throwing no codes does anyone have any idea what could be goin on help would be much appreciated. thanks
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
do you mean it rough idles when u start the car
Quinn
Car: 1992 Nissan 240SX
I have this same problem. I've tried a little to figure it out, but no luck. it doesn't idle rough at all, just has a complete lack of power right under 2K on the tach.
fenderguitarist
yeah basically thats what its doing the car idles good but it will drop a bit and almost stall then go back up to a decent rpm it will only bog if i try to drive it normal like shifting at 2k but if i hammer it i wont get the bog i dont know where to start im thinking o2 sensor or the coil
Quinn
I guess i kinda blamed it on bad plug wires. I went to pull out the first plug, and just the wire pulled out. the clamp is still on the plug. runs fine when i put it back in, just probly not the best to keep running it like that, but i need money first. i looked all around the intake, even took all the intake tubes and everything off looking for something out of place, but couldn't find it. so I'm wondering if the motor is a tiny bit out of tune and it just doesn't run right at that rpm under a light load. cause like you said, if i get on the gas it'll run fine. but thats not good to do with the weather as cold as it gets here. 30 below wind chill on tuesday, almost didn't start at all.
zenkikou
Car: 240sx
hey i have kinda the same problem... but its a little different.. when i drive it is fine but when i go over 2500rpm it starts to bog or something like that like the car doesn't want to go faster... what do you guys think the problem coud be?
s13bassboat
Car: 1993 240sx coupe a.k.a bassboat
I had the same problem that i fought with for a month and it turned out the Throttle position sensor. check your sensor and your battery ground along with all the others. let me know how it goes good luck
