KA24de block with KA24e crank
chanklas
Car: 1992 Nissan 240sx Copue Se
Will a Ka24de block work with a ka24e crank? I am asking this because i pulled apart my KA24de Engine apart and the bearings are spun and the crank is no good. But i have a ka24e long block engine laying around. So will the two work together or will i have to buy a new crank for ka24de?
seang
Car: Ford Fiesta ST
Same bore and stroke, that is all I know for sure. I'm half way sure the rod journals are the same as well, but even factory cranks use oversize bearings sometimes, according to shop manuals.
rioredstang
Car: 1993 240sx SCCA ITS
The cranks are the same, but the ka-e has (3) key ways. The de has (2). I have a ka-e crank in my de block. I made a spacer to take up the clearance between the pully and the bolt.
