ka24de block the same as a ka24e block??????
justy90240sx
Car: 90 240sx se, 95 240sx, 92 300zx
so im woundering if the blocks are enterchangeable. ive heard before that they are but i call the nissan dealer and they said the part numbers are different, but that doesnt mean that u cant put a sohc head on the dohc block. so if anyone has done it or or tried and found reasons it wont work. i really appriceate any info anyone has. thanks
justy90240sx
i searched and all i can find is forums about puting a ka24de head on a 24e block and im wanting to do the opposite e head on de block. any info?
justy90240sx
has no one tried or just no one knows if anyone has any useful info i would appreciate it. thanks
89twoforty
Car: 89 fastback
From what I've read the DE head is a little larger than the E block, so it seems the E head would be a little smaller than the DE block.
[email protected] wrote:I have had much discussion with this topic. Conclusion is that the DE head is slightly larger and hence wont fit on the E block. So no you cant just replace the head. You will have to replace the entire engine from the gearbox up (this is what i'm doing) But the gearbox is exactly the same, so you dont need to change ne thing from there down.
Its not as difficult as changeing to a totally different engine (eg. SR20)
