that aside you could've come across a little more civilizedS13FX wrote:What the **** dude do you think your driving a ****in honda or something with a ****in aluminum block or something are you ****in retarted.
Yah true hehe, if you wish I could attempt one mroe time oh and don't worry I am a very friendly guy . So elt me say this. Don't Use sleeves .EstoMax wrote: that aside you could've come across a little more civilized
mucho if you're doing a motor rebuild on your own i suggest you do a lot more reading. and talk to the guy at the machineshop a lot they will teach you a thing or two.
True. But you never know the power goals, maybe 1500hp?KATwo40 wrote:There's no reason to use sleeves in the KA. If Ivan @ AMS makes nearly 900bhp on a sleveless block, I'm sure we can do the 300-400whp we're after just fine.
Given the context of the initial post, I highly doubt it's that high.Swedish Mike wrote:
Haha, me too.KATwo40 wrote:Given the context of the initial post, I highly doubt it's that high.
Ok, listen...fiznat wrote:Sleeves will never be available for the KA because it is a closed deck design. The motor does not use sleeves at all.
It doesnt have anything to do with necessity, or power goals, or anything that. The design is simply different so that sleeves are not used. There is nowhere to put them.
Thought I'd clear that up.
Also S13FX, chill out. Jeez.
Thanks!KATwo40 wrote:^^^ That is absolutely correct. V8 guys use them sometimes.
Thanks, finally one with some knowledge!C-Kwik wrote:The KA uses a sand cast block. As a result, wall thickness variance from block to block is relatively large. This is not an issue for it's itended applications or even some fairly high boost. But sleeving with stronger materials than the block can help increase strength to reduce failure and even perhaps increase power slightly if there is flexing occuring in a thinner part of the wall. Flexing can cause some of the combustion enegry to exit the chamber like blow-by gasses. It may also cause irregular wear on the piston rings and wall. Another things this can help with is if you are trying to maximize the bore. Stronger sleeves can allow one to run thinner walls, thereby allowing a larger bore.
Having said that, I don't know the availability of sleeves for a KA. Perhaps a good shop can fabricate or modify a set for another motor to to work on a KA.
I think you'll find that there are plenty of people on this board with both knowledge as well as experience. You should watch what you say, less you piss one of them off.Swedish Mike wrote:Thanks, finally one with some knowledge!
Calm down, I don´t want to make people angry...fiznat wrote:I think you'll find that there are plenty of people on this board with both knowledge as well as experience. You should watch what you say, less you piss one of them off.
Perhaps I should rephrase. Sleeving a KA is a freaking stupid idea. Saying that it CAN be done and that it SHOULD be done are two very different things. The KA is not only closed deck, but has a fairly tight tolerance between cyls. Subtract from that whatever overbore is done for the necessary forged pistons, and you have a virtually unsleevable block unless you feel like sacrificing displacement.
I'm not impressed by the fact that some people have done this to other motors in the past under different circumstances for different setups. The fact of the matter is for this car, for this motor, for this turbo setup: the idea is not appropriate.
I LOL'ed... then I kept reading and came acrossS13FX wrote:What the **** dude do you think your driving a ****in honda or something with a ****in aluminum block or something are you ****in retarted.
and I LOL'ed again.merry christmas everyoneWDRacing wrote:I agree totally, the KA is an anchor waiting to happen...sleeving a KA is retarded at best. WD
