waxdnuggz wrote:check your fuel pressure. check the injector resistance. if it boggs comming from the previous rpm chances are your starving or gourging the engine with (air or fuel). believe it or not my last ka did that because i had a short in the old harness. make sure your harness isnt chewed anywhere. also check your electronic vitals. (12v at batt when cars off, +12.9v when the cars on, you want as close to zero ohms of resistance as possible anything over i believe 6 or 7 ohms is bad) the short i had caused me to have 38 ohms of resistance at the batt. meaning its starving something of electricity.
if its bogging only on deceleration to accel then chances are its not compression chances are its an air or fuel problem whether its from electrical or mechanical. start with that and let us know
That's the stuff you move on to AFTER you make sure the engine is in decent shape
Minimizing potential causes makes troubleshooting easier, and those things are just a good idea anyways
Compression test was a "just beause" thing since he would have the plugs out anyway. Especially if he plans to turbo it later, the comp numbers would be nice to know, ya? And if the compression Is low by chance, then he knows not to waste any money on it, or to rebuild it, or w/e. No such thing as knowing too much about your engine
cheesemounger wrote:I don't know if I did the quote correctly but while I am replacing these I wouldn't mind setting up for a future ka-t setup. By that I mean injectors and mafs because I always see people talking about upgrading or swaping SR injectors /or a300zx mafs those when boosting. So if someone could let me know what to do to prepare for a turbo , or just to beef up the engine .
Yeah, you got the quoting right
The thing about upgrading those things is you'll need a tune to make them work. If you're def gonna go KA-T, start accumulating those parts. Things like maf, injectors, fuel pump, bearings internals w/e you plan to do. Then pull the engine and do it all in one go. My 0.02. Whatever gains you get on the N/A side of things will be peanuts compared to the turbo power. There's plenty of KA-T builds on here
s-chassis-build-thread-list-t441933.html - they should give you an idea of what you're looking at and what they entail.
