ka24de and ka24e bottom end differences?
steebypue
hi, im sorry if this has been posted before but the search feature is not working correctly for me
my ka24de bottom end took a crap and i wanted to replace it, so i was wondering if i can pick up any ka24 bottom end or does it have to be from a ka24de?
if they do fit, would u recommend it?
Ni2s4s0aSnX
Car: Nissan 240sx 2.4L 12Valve
I know that you can, but it wouldn't be as good as the DE.
InsanityInc
The block is exactly the same. You'll have to use the front timing cover from the DE, though.
steebypue
InsanityInc wrote:The block is exactly the same. You'll have to use the front timing cover from the DE, though.
how so?
InsanityInc
well, since the KA24E is SOHC, you obviously need the different timing cover.
steebypue
Ni2s4s0aSnX wrote:I know that you can, but it wouldn't be as good as the DE.
oops sorry i quoted the wrong person.. i meant to quote this comment.
so... what do you mean?
TheOne
Car: 93 240sx FB
they are not exactly the same, brackets are not the same for powersteering & other accesories, the pistons are not the same i believe, it also doesn't have oil squirters like the DE block does, even some of the in-block oil galeries aren't the same.
now the height of the rods should be the same along with maybe the crank.
InsanityInc
The pistons aren't the same, but they will fit. Also, the E pistons are actually better considering they're not dished and will give you a higher CR.
All the other differences won't matter for matching it up either as they are totally internal to the block.
The only potential problem is of course the accessories, but considering I think all the accessories are the same parts (could be wrong), you shouldn't have any problem attaching them to the E block, you'll just need different belts.
steebypue
TheOne™ wrote:they are not exactly the same, brackets are not the same for powersteering & other accesories, the pistons are not the same i believe, it also doesn't have oil squirters like the DE block does, even some of the in-block oil galeries aren't the same.
so i see i should opt for a de block then
on top of that, im looking for a lower cr so de is my only option.
thx guys
