ka24de 89 coupe: Idles fine but wont rev! bogs down after headgasket install!
97gsx
Car: 1997 evo316g powered GSX
Ok we just put a new felpro headgasket on my ka24de. Now, after messing with timing like 3 times (what a PITA), it starts and idles marvelously.
However, after idling, it does not like to respond to the gas pedal? Push the gas and the rpms dip then bog/stutter.
I unhooked the TPS plug on the throttle body and once the car gets pushed past 1400 ish rpms it free revs very nicely with the TPS unhooked?
dkdeleon68
Car: 1991 240
is your MAF (mass air flow) plugged in?
180fan
Car: 89 fastback
yeah you need to have your tps adjusted or replaced.
