KAestate »
https://forums.nicoclub.com/kaestate-u42905.html
Tue Jul 18, 2006 8:45 am
My question is simple. For those of you who have done this swap I was curious as to how you mounted the transmission (240SX 5-speed) to the tunnel.
First I used the Datsun mount which bolted right to the transmission but the crossmember was a good 3-4" from the factory bolt holes in the Datsun and I had to flip the crossmember around backwards to get even 2 of the bolt holes lined up with the crossmember holes.
Then I tried the removing the Datsun mount altogether and made longer bolts with the flat head to mount the crossmember directly to the transmission to get the 2 holes that DID line up closer to each other. I then used large nuts as spacers in between the car holes and the crossmember. Still 2" away and the car drove like a go-kart... vibration-wise.
My next idea includes using the 240SX mount with the 240SX crossmember center, cut off the ends of the 240SX crossmember (as they are not symmetrical) and weld on the Datsun crossmember's wings. I know if I do a straight weld that it will still be a few inches from the car so I am planning on welding a support on each end to bring the wings closer to the car. If I try this and it doesn't work I'll have to find another crossmember.
So far I have spent $207 on this swap (electric push fans and shortening the driveshaft 8") so obviously I don't want to "cheat" and buy a custom crossmember.
So let me know how you did it, even if you DID buy the custom one.
