lukbot »
https://forums.nicoclub.com/lukbot-u49122.html
Fri May 22, 2009 3:20 pm
how exactly did u check the thermostat? put it in boiling h2o and see if it opens? the best way i have found to fill nissan cooling systems is with a vacuum filler. but without a compressor, the fsm does have a procedure that involves "burping" the system. i like a funnel with a rad cap fitting on the bottom, matco and snap on sell them as spill free funnels, they work well at the dealership when i can't for some reason use the vacuum filler. or worst case scenario is ur headgasket blown?? if combustion gasses are entering the cooling system it will cause instant air pockets.
