Oy, the stupidity of the internet.Ni2s4s0aSnX wrote:Yes, you probably don't want to use nitrous right away. But whoever posted last, you are wrong as well. You shouldn't just throw a turbo on as your first mod, because that would actually be worse that nitrous, your transmission wouldn't be ably to handle the power without modification, and a turbo would require a bigger exhaust and other various mods to get the most horsepower.
If your stock clutch isn't going to handle 200whp, it isn't going to handle a 75 or 100 shot. As for how long it's been lasting, I'll put it this way: I've never heard of a KA transmission breaking from too much power.4gotn1 wrote:but unlike the silvia/180sx the 240 comes with our blessed ka. not the sr20 or ca18. which are smaller motors.sure people have laid down 600rwhp, but how long will the transmission hold it? how good is his transmission? does it leak oil, grind gears...etc. not to mention that he would have to pull it out to put a clutch in anyways. cus i highly doubt a stock clutch taking 200whp without protesting.
After reading the KA-T forums for, well, a long time, I've never heard of that either. I think the ring lands or the rods will crap the bed long before the transmission.InsanityInc wrote:If your stock clutch isn't going to handle 200whp, it isn't going to handle a 75 or 100 shot. As for how long it's been lasting, I'll put it this way: I've never heard of a KA transmission breaking from too much power.
You are not even gonna get that high, I say 160whp with bolt ons. Some forms of performance can be cheap... compared to others. 200whp in a turbo KA is going to be cheap compared to 200whp in a NA KA.Bigvinnie wrote:I hate it when people use the word cheap. Performance isn't cheap, and if it is it isn't that effective. The highest power you will see from your KA is about 200~210 CHP (180~190whp) at the most, with bolt on mods, cams and an ecu program with the stock internals of your 9.6CR. NOS is the most effective route for quick and easy HP, but those NOS tanks start to add up in price once you go through a few of them.
"Do it right" I bet pro mod nitrous guys would kick you in the nuts for saying that. Nitrous and forced induction are equals as far as WHP goes. I just think that turbo would be more fun and economical in the long run becuase its there EVERY time you hit the gas, not just when you arm it and have a the bottle open etc etc...InsanityInc wrote:Don't use nitrous, do it right. You can throw a turbo on a stock KA very easily if all you want is straight line performance. Much safer for your internals, and you don't have to refill it. Way cheaper in the long run, too.
In stock form the SR produces around 185whp and the CA is around 150whp if you just use bolt ons with a KA you can have more WHP and torque that a imported CA18DET. Also 600whp and 200whp should not even compared, that is like saying my "I got 300 degree water poured on me and I got 100 degree water poured on me". WTF? leak oil? grind gears? My transmission does both of those in stock form. Exhaust piping size has nothing to do with price and there is no way you can make 200whp in a KA if you need nico to ask how.4gotn1 wrote:but unlike the silvia/180sx the 240 comes with our blessed ka. not the sr20 or ca18. which are smaller motors. sure people have laid down 600rwhp, but how long will the transmission hold it? how good is his transmission? does it leak oil, grind gears...etc. not to mention that he would have to pull it out to put a clutch in anyways. cus i highly doubt a stock clutch taking 200whp without protesting.
so even if the exhaust system is the same. the motors are not. the ka being about 400cc's larger, would require a larger pipe for n/a and even bigger for a turbo application, so that the motor could breathe properly. turbo would be the best way to get over 200whp. unless you want to stay na. it all comes down to how you wish to make the power.
You have to learn somewhere.Ichi-Go wrote:...there is no way you can make 200whp in a KA if you need nico to ask how.
YEA it was definetly the Ford GT with 550. but i live in a rich part of town so its not uncommon to see ferraris LAmborghinis, porshces, vipers, ive seen maseratis, maybachs, and i think 1 ENZOnaed240sx wrote:are you talking about the ford gt or ford mustang gt. Because they are VERY different cars. One has around 300 hp, the other has 550. the GT is a very rare and expensive exotic. It would be amazing if you actually saw one.
Some chats will Scooter and Devious would help a lot. And even those guys arent anywhere near 200whp.1991S13 wrote:You have to learn somewhere.
Not really, unless you're talking a junkyard turbo kit and even then it's pushing it. 200whp really isn't that hard. Just rebuild the engine with KAE pistons, throw a header, 3" exhaust and intake on and futz with your cam timing, or do a cam swap. You're looking at under a grand if you do it yourself, and you have the added bonus of not having forced induction.Kenrik wrote:You will spend more getting a N/A KA over 200WHP then you would getting a turbo KA over 300WHP it's just not worth it...
its not really that hard to get 300 with a ka.Ichi-Go wrote: There are KA's with 300hp its just not very easy, or cheap.
uhhh i think it would take more thn jus that to make 200./header/exaust/cams/and cam timing would not be enough for 200. mabey like 160-165InsanityInc wrote:
