ka24de 1996 s14 & BLITZ R-VIT RVIT i-Color Flash 3.1
ORUG@
Car: Zenki S14 Silvia
will the BLITZ R-VIT RVIT i-Color Flash 3.1 work on ka24de it says that the monitoring system will work with anything 1996 n up with OBD II
TroubleBound
Car: 1992 240SX Hatch
ORUG@ wrote:will the BLITZ R-VIT RVIT i-Color Flash 3.1 work on ka24de it says that the monitoring system will work with anything 1996 n up with OBD II
Is your car a 96? Check
Does you car have OBD-II? Check
Im going out on a limb here, but im gunna say, yes.
Car made prior to 96? No worky.
If you want to be sure, send an email to Blitz or whatever company you are buying it from, and ask them. That way if they say it will work and it doesn't, they will be responsible for your refund =)
Chaluska
you are actually incorrect.. 95 S14's also had OBD-II
SketchyRollin564
Car: SR hatchback in the werks
^nope, only the late model 95s
the early model 95s were OBD-I, mine was
TroubleBound
Chaluska wrote: you are actually incorrect.. 95 S14's also had OBD-II
SketchyRollin564 wrote:^nope, only the late model 95s
Yes many manufacturers were using OBDII for the end of the 95 model year as by 96 it was required. I was trying to make it cut and dry since reading comprehension isn't our OPs strong point. Again, a simple email to the company would have been much more quick and accurate. Or hell i don't know, he could go out and take a look at his car that would work.
