KA24DE 10.5:1 comp pistons FS
JJ240
Car: 95 white 240
10.5:1 non forged pistons for KA24DE for sale. I will take $100 shipped or send offers to [email protected]
JJ240
Car: 95 white 240
bump
JJ240
Car: 95 white 240
que? el bumpo senorita
JJ240
Car: 95 white 240
Where did all the guys with high natural-aspiration aspirations go? Someone email me a serious offer on these already!! :tisk:
robertwb70
Car: 72 datsun truck=PL-521/on 85 frame Z-24eng+cam+ported+weber38DGAS
JJ240 wrote:10.5:1 non forged pistons for KA24DE for sale. I will take $100 shipped or send offers to [email protected]
those would be plain old KA-24E pistons right?~?
JJ240
Car: 95 white 240
Originally yes, then they were milled down from 11.6:1 compression to make it more feasable as a daily driver.
PGZX3
you know, if I had the cash I'd be all over it but I need to concentrate on getting the car completely paid for and in my posession first....it you still have them in a few months (hopefully not for your sake) I'll be all over it, I promise ;)
JJ240
Car: 95 white 240
Ill let them go for $75 shipped if someone can do it within the week. Ill put up a pic a little later tonight.
JJ240
Car: 95 white 240
You should gain about 12% HP and torque across the powerband with these pistons.
robertwb70
COMPRESSION ALONE DOES NOT CONTRIBUTE AS MUCH AS MOST PEOPLE THINK-my research sayseach point of comp. increase=3-4% power increase-stock ka-24de-9.5to1-up to11.6to1=12.6hp increase(assuming stock 150hp)and you would have to retard the timing so much to run even the best pump gas you would probably lose twice that much!
why most new cars have relatively high comp. is efficiency which increases in greater proportion than power(7-8%per point)
modern engine controls are the only reason anything more than 9to1 is possible.
research from david vizard's many books-------------------------------------------------------------------------------thats way optomisticthis is a post I did before concerning compression (stock KA-24 piston swapping};)
JJ240
Car: 95 white 240
Dont preach on my sale post. Ive read many times that 10% per point of increase is a good estimate. With headers and catback you wouldnt have to retard the timing at all to run 10.5:1. Dont argue either because I had them in and tried it.
robertwb70
JJ240 wrote:Dont preach on my sale post. Ive read many times that 10% per point of increase is a good estimate. With headers and catback you wouldnt have to retard the timing at all to run 10.5:1. Dont argue either because I had them in and tried it.
sorry-didnt mean to preach-10.5 is probably fine with premium fuel-just that 10% is way high-that 3-4% per point estimate comes from many different sources and thousands of dyno test done by guys that have been there and done that before you or I were born
I dont mean any offense its just that numbers and expectations tend to get a little carried away-just trying to keep it realistic
if some one has dynoed their car before and after the piston swap with no other changes and on the same dyno please speak up-that would be interesting
JJ240
Car: 95 white 240
I doubt anyone has. Very few people bother to really NA build a KA24DE. Most people just throw exhaust/headers/intake on and call it quits.
robertwb70
yea -dyno time would probably cost almost as much as the partsthere are some on here that have the whole deal-but usualy other changes are made at the same time so its hard to compare
Im rebuilding one for my sweeties car now(91 240sx coupe)are these pistons standard bore?
JJ240
Car: 95 white 240
Yep standard bore. Basically drop in other than fresh rings and hone. They clear higher lift cams too as long as you dont adjust more than half a tooth.
PGZX3
75 shipped...dammit dammit dammit *curses*
if they're still here in a week and a half you WILL have a pay pal....lol
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
robertwb70 wrote:...if some one has dynoed their car before and after the piston swap with no other changes and on the same dyno please speak up
Rownan over on FA (maybe he's on here...??? - He has the car that was Rich Bs from 240SX.org IIRC) has I/H/E, S13 cams, ECU, pulley, etc...and 11:1 pistons and made ~170rwhp.
I made 160rwhp with basically the same mods...
So add his pistons to my old N/A setup and you get a gain of 6.25%...still higher than what I've read/seen (which is 4% BTW...), but not a 15-20rwhp gain.
Later - Brian
JJ240
Car: 95 white 240
Rownan used to post here. When I was first looking into going high compression he was one of the people that responded to my questions.
JJ240
Car: 95 white 240
bump :(
p00t
i would definately want them when i swap in a new engine and build up my old KA to sell for some $$$$$, but thats not for a very long time. sorry man, but an extra bump by me for some cheap HP!!!!!
i love when **** rhymes!!!!!
Silent Drifter
Car: '93 Nissan hatch
'90 Nissan coupe
'96 Ford Ranger
Looking for a bike!
damnit i wish i wasnt broke this week id by them im rebuilding my ka an some newer pistons wouldnt hurt
Silent Drifter
'90 Nissan coupe
'96 Ford Ranger
Looking for a bike!
Id be willing to buy these pistons if you give me more details about them, brand milage put on them, an if i got these will I need to do any other mods to run the 10.5:1 compression without screwin up the rest of my motor?
JJ240
Car: 95 white 240
They have about 15 miles on them. They are Nissan pistons. You will need new piston rings, and a fresh bore hone, You should have headers and exhaust at least to run these, although you can run them on a completely stock motor if you retard the timing.
Silent Drifter
'90 Nissan coupe
'96 Ford Ranger
Looking for a bike!
Will these work on the DOHC motor as well because thats what Im planning on puttin them in, an if so I will buy them from you. But just one questioned if their 10.5:1 compression only 15miles on them why are you selling them for 75 shipped.
JJ240
Car: 95 white 240
Yes they will only work in the DOHC motor. Im selling them for $75 because theres not a huge demand for them. I was asking $100 but noone took it. I hate to have them sitting around when someone could be using them, and I have need of the cash right now. If you truly are interested in them toss me an email and we will get it figured out. Hope to hear from you soon. [email protected]
my1st240
I sent you an email. Are the pistons still available?
Silent Drifter
'90 Nissan coupe
'96 Ford Ranger
Looking for a bike!
I already bought em
my1st240
Well, ok. Thanks for the reply.
