ka24/sr20 transmission; are they interchangable?
s13sucksalot
Car: 1991 240sx se
well, i've heard everything on this one. A.) yes! the ka and sr20 do share the same transmission (along with some other motors). B.) No, something about the size and mounting of the clutch (meaning a new one would be needed). The reason i'm asking, the transmission on my KA is dying. a lot of bearing noise. if a SR20 will fit, it will help me with shopping options. Any help would be really appreciated here. thanks.
Import_Ant
the difference is in the bellhousing. if you remove your KA bellhousing and put it on the SR transmission it will work. same goes for the CA transmission.
Modified by Import_Ant at 7:42 PM 5/5/2005
s13sucksalot
Car: 1991 240sx se
really?... havn't heard that one. i'll take that into consideration. thanks alot. check your cardomain site. i left a message.
PandaS14
Car: S14
Yes, internals are the same. Just need to swap bellhousings to get it to work.
USDM240
Car: 1993 Nissan 240SX Limited Edition 'vert
what he said^
s13sucksalot
Car: 1991 240sx se
cool, i like hearing the same thing from like.... 3 different people!
s13sucksalot
Car: 1991 240sx se
well, ordered the SR20 transmission, i'll post what happnens when i it. thanks guys
R240sx
Car: 1990 Nissan 240sx
I dont think you should of bought a sr transmission b/c the ka and sr have the same internals (atleast i think so right?) and the sr bellhousing wont fit on the KA.
s13sucksalot
Car: 1991 240sx se
yeah, they do have the same internals. by swapping the bellhousings on the two trannys, you can make it fit. the reason for buying a SR20 transmission is b/c no one locally has a manual transmission for the ka, and if i wanted to buy one off ebay, i'd have to get a motor and everything with it. i could have waited around to see if one might have popped up, but i don't have a clue how long my transmission is going to last. this is going to be a fun project!
Dattebayo
People tell me that the KA transmission is more robust than the SR transmission even though all the gears are of the same exact ratios.
If you are using a SR, I was told you should just get a bellhousing for SR and use the KA everything else.
Also, the speed sensor might not work depending on what year the car is.
Riceless
Car: 84 300zx turbo
Out of curiosity s13sucksalot... were you pissed off at your car when you registered or something?
I figured if I was going to hijack and ask it may as well be your thread
s13sucksalot
Car: 1991 240sx se
yes actually, i was. i had been working on replacing my head gasket for... oh... about 2 weeks. i had finally gotten the car running, but it kept over-heating. finally solved the problem by dislodging some junk in the water jacket in the block... anyhow, now you know!
Riceless
Car: 84 300zx turbo
saintsinner
Car: 1989 nissan 240sx fastback
ooooo all good thins to kno
