KA24 SOHC ECU Error 35 Exhaust Gas Temperature
WhiteKnight
Car: Nissan 240SX
I searched everywhere...can't find an answer for this.
What sensor gives Code 35? Is it the EGR temperature sensor?
The code says it is Exhaust Gas Temperature.
Where is it in the manifold?
Modified by WhiteKnight at 5:07 PM 11/2/2009
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
its the egr temp sensor. only for cali models. if you have a cali ecu, but a federal motor, itll throw the code. other reason, the ecu uses this sensor to determin if your egr valve is functioning. if it isnt, it will not see the temp and it will set a code. its in the intake manifold, close to the egr inlet
mick
Car: 1990 240SX
Thanks...I replaced the egr solenoid last week....I found these sensors for $100 at rockauto
