ka24 problems
civicslayer21
Car: 1989 240sx 2 toner
okay i kno everyone is goin to tell meto search but i did and nothing came up so......i have an 89 ka-24 and from 1,000-3,000 rpms the engine hesitates ans boggs. i have no idea whats goin on. i just got a tune up with new cap plugs wires and rotor as well as a new battery. any and all suggestions would be appreciated
Jackask89nissan
I had a similar problem w/ my 89 240sx check your tps sensor and check for vacum leaks. check your Ecu for codes as well and go from there.
VeloceDrift
Car: 1993 Nissan 240SX S13 coupe
1995 Nissan KA24DET
check your MAF as well.. it can cause some major problems if it is not plugged in all the way..
Alastaplat
Car: 1989 240sx
I had that problem and it was the last thing I would think of. after I replaced a bunch of other things I found out it was that alternator.
civicslayer21
yeah i got a new maf for the car but i will try the others. ill let u kno. but keep comin with the ideas because it runs like a 2 cylinder lol.
