ka24 not starting...
RosCoe
Car: 1989 Nissan 240sx
engine is cranking but not turning over...gettin spark...wut cud this be....i need help fast....cuz i wanna get this thing running for the summer....
Import_Ant
if you're getting spark and it isnt running then you're not getting fuel. check the fuse to your fuel pump (in your engine bay, it's in the fuse box behind your battery) is this a recent prob that started or did you buy the car like this?
p.s. you might take out that huge pic... it doesnt help much
SlidnSideways
Car: 97 Nissan 240sx SE
Need alittle more info. Did you buy like that? Did it just not start one day? Did u miss a gear or something that may have caused the timing to be off?
If your getting spark i would check fuel like he said. If you have fuel, make sure ur MAF isnt messed up maybe causing you not to get air.
If perhaps you missed a gear and the car stalled out and wont start it may be more serious like timing chain (im working on fixing that for my 240 right now because of similar symptoms)
