ka24de_510 »
https://forums.nicoclub.com/ka24de-510-u321.html
Wed Jan 29, 2003 12:50 pm
Get some 3/4 inch steel spacers and it will mount right up to the stock motor mounts. The transmission is a bit more of a hassle, you have to make some adjustments there (or just drill some extra holes in the floor).
The wiring will basically be completely different than the 510, but it's not that hard. The exhaust system will require a little fab too. Remove the whole EGR system, and if you want you can hook the speedometer up to the ka transmission with an old 1978 280zx part that you can get at a junkyard for $5. The driveshaft will need to be shortened as well.
Other than that, get as much of the sensor info to the ECU by whatever wiring routes look cleanest to you, get an aftermarket air filter system, relocate the battery to the trunk
