richard bb wrote:the car is an auto transmission fastback. it is tumbling fine, meaning that the battery terminals are good & so is the starter.
i didn't open the distributor cap as yet, because i'm getting a proper spark on the plugs...... i'm also getting gas to the injectors.........that's why i'm soooo bafled.
Don't be so sure on "proper" spark. You're just getting "spark". What's the gap? Should be at .44 I believe. Do you have to hold the ignition for a second before you 'get' spark? It should spark almost immediately.
How are you sure the gas you're smelling in the cylinders (I'm assuming that's how you know you're getting gas to the injectors) isn't old gas? It could also be too MUCH gas, which would lead me to believe the problem is your CTS.
I'd check the dizzy first, then go from there. If it's OEM, replace it. Do the rotor too. If your plugs aren't higher-end, replace those.
You didn't answer my question about the check engine light...
