KA20E 20MPG good or bad?
90KA24E
Car: CARS
Totally stock with a hole under the muffler the size of a small hand!
Is 20MPG good or bad for a KA24E with 108000 miles on it 5 speed?:help PEople told me is bad but it's a Truck engine so!
Blazin Hondas
Car: Working on stuff
Yeah thats pretty good, The KA24de stock ( I think ) gets 20mpg if you drive carefully. I drive the he/@ out of mine, I get about 17mpg on fouled plugs. It all depends on how you drive. Mash the gas and it goes down, smooth throttle gets better.
90KA24E
Car: CARS
Thank's
This site is slow!
Bay Dog
Car: 1985 300z Turbo
If you look at threads in the technical section, you will find they a few that deal with this topic. From what is there, 20 is about standard.
This thread should probably be moved out of this zone.
SHIFT_Z
Car: On 4's
2019 Subaru WRX 6MT
Former:
2014 Chevrolet Cruze 1LT
2006 Nissan Altima SE-R 6MT
1988 Nissan 300ZX 2+2
1985 Nissan 300ZX Turbo
1986 Nissan 300ZX Slicktop
On 2's
2018 Kawasaki Ninja 400 ABS
Be lucky you get 20. My ZX gets 17 when I granny drive it, and worse when I push it.
90KA24E
Car: CARS
I only get 14MPG now! That is babying the hell out of it. Change gear around 2500RPM.:icesangel
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
I have the same issue with low MPG. I added a WAI and it all went down hill from there. On a not so busy day at work I hooked up ConsultII and monitored some of my signals going into the ECM. I noticed that the Coolant Temp Sensor was reading funny to me. I pointed my Raytek infrared temp gauge at the Coolant Temp Sensor and found it to be about 25 degrees warmer than what it was telling the computer it was. After fully warming up the car it was still reading much lower than what it was telling the computer it was. This is by the way something I havent fixed yet and it is keeping my car from going into closed loop most of the time. I plan on checking it again this week to confirm it and then I will replace the sensor. I'll keep you posted as to whether or not the MPG problem was fixed or not.
Queamore
Car: Cars.
I get 10 in my 75 Malibu 8 when I hot rod it.
