KA vs. SR transmission??
SR20S13
Car: 1993 Nissan 240sx - SR20 INSIDE....
so my 4th gear is going out in my car and i have the old ka trans at my house...i know i can swap the bellhouseing but i kinda wanna build it but idk which one to do b/c i know the gearing is different...
whats everyone think/have??
SlideWayzS13
Car: 89 S13 coupe Swapped srBlkTop
Same exact trans.....just swap bellhousings and ur set.....if you drift or race ur car dont spend money on a built trans unless u have the extra cash to waste. Cause ur just gonna break it again
240_SeX
Car: 1992 240SX SE
the only difference is that 5th gear is slightly longer, its almost not noticable. you just tach a little lower in the highwaylower RPM= better MPG
boro drift
Car: '87 Supra, '92 240 with SR20 and '98 12 valve Cummins
I'm positive that even the 5th gear is the same. I had a KA and a SR transmission disassembled and I counted every tooth on every gear, gearing between the two are identical. Is your transmission making noise in 4th or grinding going into 4th?
240_SeX
Car: 1992 240SX SE
KA24DE 1st- 3.3212nd- 1.9023rd- 1.3084th- 1.0005th- 0.759
SR20DET5spd--1st: 3.3212nd: 1.9023rd: 1.3084th: 1.0005th: 0.838Reverse: 3.382Final Drive: 4.083
jr_ss
Car: 95' S14
240_SeX- Where did you get your information from? Every single spec I pull up it's exactly the same...
Tulsa_S-13
Car: 1991 SR 240sx
The S13 SR and ALL KA transmissions are the same, 240_SeX is pulling his from the S14 SR20DET factory shop manual which indicates that the S14 SR has different gearing.
240_SeX
Car: 1992 240SX SE
Hijacker wrote:a slight improvement. The change isn't that dramatic, though.
The SR uses an .838:1 gear ratio and the KA uses a .759:1 gear ratio
So if I'm actually able to keep this straight, which I have difficulty with gear ratios I might add, the KA's gear will allow the engine to turn slower given the same road speed.
Found here zerothread?id=278158
I also found the same specs in various google searches.
boro drift
Ok,ok, I believe you! Obviously I didn't have these 2 trannys disassembled and I don't know how to count.
240_SeX
Car: 1992 240SX SE
Listen a$$, im just showing what i found. I have done the KA bellhousing swap on my SR and it tachs lower in 5th, can you explain that if its the same gear ratio??
boro drift
I'm not gonna argue anymore about it with you, so I'll leave you with this.
If you get a chance in the future to personally view each disassembled trans,(s13 ka and a s13 sr), count the teeth on each gear.
slow s13
Car: cars, photo, music
the ka input shaft is slightly smaller after the splines it necks down where the sr input shaft does not do this and is a thicker
