KA upper timng chain cover
fabio420
Car: 1995 nissan 240sx se
OK, so I pulled off my timing chain cover to swap the head. I was having a hard time removing the distributor from the upper cover, so I left it on. Now I can fit the upper cover with the distributor on, and the distributor won't come off for anything. Is the distributor supposed to be off the upper timing chain cover/ If so is it supposed to be easy to take off? Can it be that they got microwelded? If so, what do I do? Please help me asap, as after a month, this is the only issue I have right now to make my car run.
NISTECH
You need to pull the distributor out. After you remove the 2 10mm bolts holding it to the cover you have to rotate it back and forth while pulling on it to work the rubber oring free from the cover.
fabio420
So it is supposed to be pretty hard to remove?
NISTECH
yea, I removed mine a couple weeks ago when I pulled my head , had to use a long screw driver to give it steady out ward force while i rotated it back and forth working it out of the cover. Of course the cover was still bolted to the engine.
fabio420
Damn You!! LOL
fabio420
I still can't get the distributor out of the top timing cover. Is it possibly f#$%^d up? Do I need to get a new timing cover and distributor.
NISTECH
Ok here is what your dealing with. Distributor is out. The second picture is the top front cover.
fabio420
ks NISTECH. You are being very helpful. 2 more quick questions: First, what is the right way for the distributor to go in without messing up the block and camshaft timing? Second, I think I'm gonna need a new timing cover and distributor. How many years back can I go and still be compatible with my engine? I have an 95 s14 240 with dohc. (Then its off to the junkyard)
