007jpang wrote:thanks for all the imput guys... but i think i might engine swap to the newer ka models first then turbo.
would the ka24de s14 engine be better than the ka24de s13 engine for high boost because i love boost.
95silviase wrote:TurboCalculator is awesome
Jpang, becaues the ka24e has high compression, you will need to be careful with boost. Plus those headgaskets love to blow, so...But just make sure you have plenty of fuel going to it at all times, your timing is set, and you have (obviously) enough air to compensate the fuel, and you should be ok. Just dont try to run crazy boost numbers.
