fantabulous »
https://forums.nicoclub.com/fantabulous-u19259.html
Thu Nov 04, 2004 8:04 pm
i blew my SR trans. im using ka trans with sr bellhousing setup. no you do not have to swap internals. why would u want to swap internals if the one in your SR are messed up already? an impact gun will be helpfull because its hard to break the bolts loose and hold the transmission still while using a breaker bar. remove input shaft bearing retainer(quill- thing that throw out bearing rides on). theres a paper gasket u need to replace there ($3) its a good idea to replace the bearings and rear outputshaft seal too. dont remember the prices. bell housing was difficult to separate. get a block of wood to protect bell housing, and hammer to separate. where sr bell housing meets back half of trans, theres no gasket, use RTV, but use it sparingly. mate ur SR bellhousing to ka trans. took me 1 hour to replace in and out of car.
