KA transmission PROBLEMS
sr2092
I HAVE A 5SP KA AND WHEN I START IT UP IT MAKES A GRINDING NOISE FROM HELL. ONCE I ENGAGE THE CLUCH PEDEL IT STOPS. CAN ANYONE GIVE ME A CLUE ON WHAT THAT COULD BE.
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
sr2092 wrote:I HAVE A 5SP KA AND WHEN I START IT UP IT MAKES A GRINDING NOISE FROM HELL. ONCE I ENGAGE THE CLUCH PEDEL IT STOPS. CAN ANYONE GIVE ME A CLUE ON WHAT THAT COULD BE.
this can be so many different things..more info needed.
sr2092
Starting from the begining I was on my way home and I notice a mild metal to metal grinding sound, so I kept driving for about a mile and it started to lose power. I instanly pulled over and the grinning sound got really loud. I cut the car off, look under car and made sure I didn't have any fluid leaks. The funny part is, once I engage the clutch the noise goes away. The car will go in every gear but will not launch. So it is not driveable and I'm hearing that it may release bearing .
motoman399
Car: 98' wrecked (RHD coming soon) 240
check and make sure its bolted to the engine all the way. and if it makes the noise when you let the clutch out its not the release bearing. its probably transmission bearings. did you fill the trans to the right level when you installed it? check and double check!
