ka transmission problem
jedis13
Car: 1989 nissan 240sx
sorry if this has been asked beforei searched for an hour and couldn't find anythinganyways i pulled my ka transmission to change out the throw out bearingnow im trying to put it back in but everytime i get the input shaft to line up it wont go all the way in.. there is about a 1 inch gap between the bell housing and the engine.. does anyone know what this could be?? do i just need to mess with it and wiggle it around until it slides all the way in??
big monkey racing
Car: 1990 240sx
do you have the guides lined up cause that was my problem
jedis13
big monkey racing wrote:do you have the guides lined up cause that was my problem
when you say guides do you mean the teeth on the input shaft?ive tried rotating the transmission a little while pushing and no luck
dvdmex
Car: 92' nissan 240sx
The guide looks like a black plastic tube with teeth and you have to line up the flywheel ,clutch and plate and to get the transmission in that extra in rotate the that little gear thing that goes to the drive shaft then gigle the transmission and it will go in, well thats what I did and it worked.Good luck
dvdmex
I ment jiggle not gigle
jedis13
oo the alignment tool loli made sure that was all lined up even tho i didnt do anything to the clutch.. just replaced the TO bearingi think i just need to try rotating the gear that goes to the driveshaft like you said.. thanks for the info
RustspecS13
Car: '74 260z and '88 300zx turbo
Did you take out the shifter? When I drop just the transmission and I'm putting it back on some times I put it in upside down. Then when the input shaft is in place you turn the transmission right side up while pushing forward and it usually slips right in place.
I also have the engine jacked up by the harmonic balancer (with a block of rubber or wood under it and not much pressure) a little bit so the angle is more inline with the transmission while your putting it in.
GL~Alex
big monkey racing
Car: 1990 240sx
i ment the tabs that align the bellhousing to the block
jedis13
my shifter IS out and i have my engine jacked up a little bit on the oil pan.i have tried spinning the gear that goes into the driveshaft, still no luck.should i pull the trans back out and grease up the input shaft??anymore suggestions? this is getting really frustrating
deego92
Car: 1995 240sx Q
juat keep jiggling, i had to got at it for almost 2 hours before mine went in
dvdmex
Keep jiggling it dude it will go in just jiggle and push if you can try to have someone help it will make it easier.
zapracing
Car: 1993 240sx
i had to change the pilot bushing and pull the old one to get mine to go in after doing just the trans once i decided to just pull motor and trans at once because its a pain
dcdrift9
Car: 240 pignose
Just make sure you dont jiggle too hard!
cleopp3
Car: 93 nissan 240sx
I always rotate it back and forth, while "jiggling" have someone or a jack in the rear of the transmission as well!!
jedis13
thanks for everyones advicei got my car up and running
