KA transmission on an RB -- I tried to search first!
brkn240
Car: '90 240sx w/KA24DE
I'm asking for someone else on another board, because I honestly didn't know the answer, and I DID try to search first!
When doing an RB swap what (if any) mods are needed to use the KA24's transmission?
I think I've heard of people using the stock transmission, but I'm not 100% so I didn't wanna give the guy inaccurate information.
Joe
it will not bolt onto a RB.
ryan15
Car: 1990 240sx
Wrong it will bolt up, you have to drill out a hole or two a little bit but all the holes line up except 1 or 2, not worth it though, you will have to cut a little out the shifter hole on the body and also you will need a custom drive shaft is the whole transmission is longer.Ryan
Joe
ryan15 wrote:Wrong it will bolt up, you have to drill out a hole or two a little bit but all the holes line up except 1 or 2, not worth it though, you will have to cut a little out the shifter hole on the body and also you will need a custom drive shaft is the whole transmission is longer.Ryan
thats not bolt up sweetie, thats modify to make fit.
midnightsliding
so you can use a KA transmission with modified holes and nothing else?
ryan15
Car: 1990 240sx
Yea like I said basically you can with a little MODIFYING but its not worth it... its basically going to cost the same for the driveshaft as another rb transmission would.Ryan
midnightsliding
well it dont matter to me b/c i have to get a new DS anyways and its not going into a 240 anyways so i have to make new shift linkage
Shahee1
Car: 1993 240sx w RB20DET
I used RB bell housing on ka transmission ... true you have to get your driveshaft modified or buy an aftermarket but from now on you can use ka trannies which are really cheap. It works well if you are not making big power.
adam-gtX
it works just read a thread about it earlier however, it does require some minor mods.
