^^^^^^^^^Reno wrote:you need the ca bell housing to bolt up to the ka transmission..
I dont know how to answer that... Feels like any other S-chassis transmission240sxbobbis wrote:c-rad how is it on ur ca well how does it feel?
There's a bunch of bolts all around where the bellhousing meets up with the transmission. They need to be removed. In addition, there is a plate inside the bellhousing that needs to be unbolted. There are several shims and ball-bearings inside that like to go everywhere once it's opened. A rubber mallet comes in handy when trying to separate the housing from the transmission.240sxbobbis wrote:ok i guess that should answer my question lmao but how long did it take and what did you have to do ?
whats your cruzing RPMs with the KA trans in 5th? an what diff gears do you have KA or CA diff?c-rad wrote:
