Carl H wrote:on my front clip :P.lyon, im curious to know why you say that as every car ive done an auto to manual swap on i use the respective trans xmembers.the auto one from a ka will not work on a manual ka, its mounting point on the trans is in a diffrent spot and vice versa.
If your saying that for every swap you do you use the same transmission xmember that came with the 240 then yes I am saying the same thing, maybe I didn't explain it very well.. That's what I was trying to convey that if you're doing a 5 speed rb20 swap on a 240 you would use the same transmission xmember the 240 had originally installed..Does this sound better?
