s13drft89 »
https://forums.nicoclub.com/s13drft89-u31033.html
Fri Jan 27, 2006 5:46 pm
Hello,Well heres the story, my headgasket had blown on my motor, i had changed the gasket out blah blah blah, well problems started happening with the motor. Well while i doing my headgasket changed I had taken out the motor, i replaced my clutch, throw out bearing, pressure plate, as well as the pilot bushing(while the enigne and transmission was out). Well I put everything back in and started the car, the clutch felt great no noises, nothing. Well a week later I found oil leaking between the head and block, well luckly my next door neighbor was selling his 92 240, so i switched out the motor and i kept my old transmission and used my new clutch, i did everything the same why as i did with my old motor(putting the clutch in). Well I put in back my motor, hooked up everything, bleed the slave, oh yea forgot to mention i had the master, and the slave replaced around 4 miles ago. Well after bleeding the slave, the peddle felt great, I turned on the car, well i had my foot all the way down on the clutch, and then i started to hear some sort of grinding noises, like my throw out bearing, now i know for a fact that when i had connected my old transmission into my new motor, the bearing was in its perfect place, hasnt been touched, also with a good amount of grease. Now i had talked with a fellow nico member to see if maybe we can figure out this problem, he had given some suggestions to try and bleed the dampener, then bleed the slave again. When out yesterday and bleed both about 3-4 times each. Now for some reason my pedal feels spungy, and you have to push all the way down in order to put it in gear. Usually the hard spot is on the top, but mine is all the way on the bottom. Also with the noises, say if i were to push down on the clutch pedal 4 times it would only make noises twice out of the four. I checked my transmission fluided, was perfectly fine. Please any help would be appreciated, thanks-Ricky
