ka to sr harness
nis-s13
well i'm starting to do a sr swap but i had a question about the wires that connect to the sr transmission. see I'm running the ka harness from the alternator/starter side, and there's 4 clips not in use. well i know that two are suppose to connect to the sr transmission which is the neutral and reverse sensor. but which of the 4 clips from the ka harness are the ones to connect to the reverse/neutral clips....thanks if any can help.....i'm a newbie
