Bigvinnie »
https://forums.nicoclub.com/bigvinnie-u27626.html
Wed Jan 10, 2007 2:40 pm
In any case if you are looking for a shorter fifth gear you can look into the CA18de transmission it used the FS5W71C transmission with the same length. NISMO sells the shorter 5th ratio that came from the CA18det transmission to e used are our 240sx FS5W71C transmissions.You can also look into the FS5W71C transmission from the Z31 300zx 1986-1989, although that 5th gear is the same as the KA.There is also the FS5W71B transmissions that were used for the NAPS motors they as well can be used, but the speed sensors would need to be retro fitted, they also share smaller 5th ratio's than the 240sx. You can only use the transmission from the early 80's 200sx, or fab a new drive shaft if you chose to use the truck transmission's which are longer in length.
